buddypoor
Hi raja.sedt !
Up to now I didnīt have time to check your circuit in detail. However, your collection of questions is rather confusing, because several times you speak about loop gain greater or lower than 1. Please note, that the loop gain is a FUNCTION and not a specific value ! Thus, it it is not easy to understand your problem. If you are interested in stability questions you have to consider, of course, also the PHASE of the loop gain function. But I suppose you are aware of that, donīt you ?
