Jul 1st, 2025, 11:47pm
question about gainboost OTA (Read 5186 times)
lonemy
hefei anhui china
Apr 23rd, 2009, 7:58am
dear all:
   i am working on a gainboost OTA. the gain of main OTA(folded cascode) is 40dB, phase margin is 80deg and GBW is 200MHz. the gain of booster OTA(N and P are folded cascode as well) are 30dB, phase margin are 60deg and GBW are 300MHz.
  after boost, the gain is about 70dB, but the GBW change to 270MHz. we know the GBW is gm/CL, but the booster OTA never change gm and CL, why this happens?
View Profile lonemy   IP Logged
subgold
Re: question about gainboost OTA
Reply #1 - Apr 23rd, 2009, 9:13am
gm/CL is a very rough 1st order estimation. Now, neglecting the impact from all the nondominat parasitic poles, you already have at least two poles in the loop, the pole from the boost amp will result in a pole-zero doublet, that's why the GBW of your main amp increases. you must be careful about the selection of your poles, otherwise you may get some ugly settling. and i doubt it is a good scheme to have GBW of the boost amp larger than that of the main amp.
raja.cedt
Reply #2 - Apr 23rd, 2009, 9:59am
hi,
   can you please post the schematic,and please check the parasitic poles,i guess there are some poles near to the dominant pole or near to the UGB.
Rajasekhar.
lonemy
hefei anhui china
Reply #3 - Apr 24th, 2009, 7:56am
hello everyone:
   i re-designed my circuit today, this time i changed the phase margin of my boost OTA to 85deg. after boost, the change of GBW is very small (from 205M to 220M).
  i think the change of GBW is come from the feedback of the boost OTA. because the phase margin is not enough, there will be imaginary poles exist in my circuit after boost. the imaginary poles will enlarge GBW of the whole OTA. am i right?
  the attachment is the schematic of my circuit.
lonemy
hefei anhui china
Reply #4 - Apr 24th, 2009, 7:58am
i am sorry i forgot the boosters.
lonemy
hefei anhui china
Reply #5 - Apr 24th, 2009, 8:12am
subgold wrote on Apr 23rd, 2009, 9:13am:
 there is a famous paper "A fast-settling CMOS op amp for SC circuits with 90-dB DC gain", in this paper the authors point out the fu1(fu1 is the GBW of the boost OTA) should be larger than β*fu2(fu2 is the GBW of main OTA, β is the feedback factor) and less than the p2(p2 is the second pole of main OTA). so i choose the fu2=200M and fu2=300M, did you mean 300M is not enough? so how much should be enough?
raja.cedt
Reply #6 - Apr 24th, 2009, 9:12am
hi,
  i  understood the problem, you have to keep boosters ugb grater than the ugb of the main OTA,so you are keeping one booster 200mhz and another booster at 300mhz.so please increase its 200mhz booster also to 300mhz, then i am sure your problem will solved. While designing this kind of circuits you keep chaging the booster ugb and find pole and zeros .
if you are interested  you just watch the below 11th lectureslectrehttp://webcast.berkeley.edu/course_details_new.php?seriesid=2009-B...
Rajasekhar.
lonemy
hefei anhui china
Reply #7 - Apr 25th, 2009, 1:44am
dear Rajasekhar:
  i set the UGB of the main OTA at 200M, and the UGB of both two boost OTAs at 300M.
  i think the key of this question is the phase margin of the boost OTAs. and you?
