Jul 18th, 2024, 2:34am
How to make default settings in ADE? (Read 2808 times)
subgold
Apr 23rd, 2009, 9:23am
im using cadence 5.10.41. i would like to save a default setup for my ADE, such as waveform tool, plotting mode, etc. does anybody know how to do that?
i know that is not critical for the design, but sometimes these trivia can become really annoying....
Re: How to make default settings in ADE?
Reply #1 - Apr 24th, 2009, 6:33am
These are typically done with cdsenv settings. You can set things up the way you want, and then do Options->Save Defaults in the CIW. You may want to edit the file afterwards to just keep the settings you really want to set - the names are normally pretty obvious.
For example, the ~/.cdsenv to set "wavescan" as the default (it's the default anyway) is:
asimenv.startup cds_ade_wftool  string  "wavescan"
Andrew
subgold
Reply #2 - Apr 27th, 2009, 1:30pm
Andrew Beckett wrote on Apr 24th, 2009, 6:33am:
Andrew
thank you very much!
