Jul 16th, 2024, 8:42am
variable capacitor linked to an RC circuit (Read 3160 times)
Seario
Michoacán
Apr 24th, 2009, 10:16am
Hello guys...
I'm trying to implement a code where a variable capacitor is interconnected with a RC circuit in which the resistor is also variable... Yes it sounds quite bizarre and indeed it is. I've tried several things, but my lack of experience and time are killing me, so I claim for your feedback and help... When I try to run this code in smartspice it shows quite crazy results...
I'll appreciate if you can help me...
Cheers
Seario
My Verilog-A code is:
`include "discipline.h"
`include "constants.h"
module blue(p,n);
             inout p,n;
              electrical p,n,internal;
branch (internal,n) br_resist;
branch (p,internal) br_capvar;
parameter real V_rest = 7.0;
parameter real Vmax   = 25.0;
parameter real V_pin  = 17.0;
parameter real CC = 0.30281f from [0:inf);
real Vg;
real ITB;
real lock;
real lock1;
real flg;
real Eq1, Eq2, Eq3, Eq4, Eq5, Eq6;
real salida;
real salida1;
analog
     begin
           Vg = V(p,n);
if(abs(Vg) <= V_rest)
     begin
     lock  = 0;
     lock1 = 0;
if(Vg > 0)
     flg = 0;
     else
     flg = 1;
if(Vg == Vmax)
     begin
     lock  = 1;
if(Vg == -Vmax)
     begin
     lock1 = 1;
if((Vg < Vmax) && (lock != 1))
   begin
     lock = 0;
if((Vg >-Vmax) && (lock1 != 1))
     begin
     lock1 = 0;
if((Vg > 0) && (lock == 0))
     begin
       if((Vg >= 0) && (Vg < V_pin))
                 begin
                 Eq1 = 5.69e-15*exp(0.0123*V(br_capvar));
                 salida = Eq1;
if((Vg >= V_pin) && (Vg <= Vmax))
                 begin
                 Eq2 = 6.69e-15*exp(0.0299*V(br_capvar));
                 salida = Eq2;
                 ITB = 0.0068*exp(0.2583*V(br_resist));
                 salida1 =  ITB;
if((flg == 0) && (lock == 1))
           begin
                 if((Vg >= V_rest) && (Vg <= Vmax))
                       begin
                     Eq3 = 3.945e-15*exp(0.0507*V(br_capvar));
                       salida = Eq3;
                       salida1 =  ITB;
if((Vg < 0) && (lock1 == 0))
     begin
           if((Vg <= 0) && (Vg > -V_pin))
                 begin
                 Eq4 = 5.69e-15*exp(-0.0123*V(br_capvar));
                   salida = Eq4;
if((Vg <= -V_pin) && (Vg >= -Vmax))
                 begin
                 Eq5 = 6.689e-15*exp(-0.0299*V(br_capvar));
                 salida = Eq5;
                 ITB = -0.0068*exp(-0.2583*V(br_resist));
                 salida1 =  ITB;
if((flg == 1) && (lock1 == 1))
           begin
                 if((Vg <= -V_rest) && (Vg >= -Vmax))
                       begin
                       Eq6 =  3.945e-15*exp(-0.0507*V(br_capvar));
                       salida = Eq6;
                       salida1 =  ITB;
I(br_capvar) <+  ddt(salida);
I(br_resist)  <+  salida1 + CC*ddt(Vg) + I(br_capvar);
Re: variable capacitor linked to an RC circuit
Reply #1 - Apr 24th, 2009, 3:04pm
I have not checked your model in detail, but I have the following comments:
You should start by reading the paper on modeling nonlinear capacitors: http://www.designers-guide.org/Modeling/varactors.pdf.
You should get rid of the equality tests on real numbers (Vg == Vmax), the chance of those ever being satisfied is negligible.
The fact that you add the capacitor current into the resistor is very unusual, and probably wrong.
You should also be careful about discontinuities, as they will cause convergence problems.
