Seario
Michoacán
Hello guys...
I'm trying to implement a code where a variable capacitor is interconnected with a RC circuit in which the resistor is also variable... Yes it sounds quite bizarre and indeed it is. I've tried several things, but my lack of experience and time are killing me, so I claim for your feedback and help... When I try to run this code in smartspice it shows quite crazy results...
I'll appreciate if you can help me...
Cheers Seario
My Verilog-A code is:
`include "discipline.h" `include "constants.h"
module blue(p,n); inout p,n; electrical p,n,internal;
branch (internal,n) br_resist; branch (p,internal) br_capvar;
parameter real V_rest = 7.0; parameter real Vmax = 25.0; parameter real V_pin = 17.0; parameter real CC = 0.30281f from [0:inf);
real Vg; real ITB; real lock; real lock1; real flg; real Eq1, Eq2, Eq3, Eq4, Eq5, Eq6; real salida; real salida1;
analog begin
Vg = V(p,n);
if(abs(Vg) <= V_rest) begin lock = 0; lock1 = 0; end
if(Vg > 0) flg = 0; else flg = 1;
if(Vg == Vmax) begin lock = 1; end
if(Vg == -Vmax) begin lock1 = 1; end
if((Vg < Vmax) && (lock != 1)) begin lock = 0; end
if((Vg >-Vmax) && (lock1 != 1)) begin lock1 = 0; end
if((Vg > 0) && (lock == 0)) begin if((Vg >= 0) && (Vg < V_pin)) begin Eq1 = 5.69e-15*exp(0.0123*V(br_capvar)); salida = Eq1; end
if((Vg >= V_pin) && (Vg <= Vmax)) begin Eq2 = 6.69e-15*exp(0.0299*V(br_capvar)); salida = Eq2; ITB = 0.0068*exp(0.2583*V(br_resist)); salida1 = ITB; end end if((flg == 0) && (lock == 1)) begin if((Vg >= V_rest) && (Vg <= Vmax)) begin Eq3 = 3.945e-15*exp(0.0507*V(br_capvar)); salida = Eq3; ITB = 0.0068*exp(0.2583*V(br_resist)); salida1 = ITB; end end
if((Vg < 0) && (lock1 == 0)) begin if((Vg <= 0) && (Vg > -V_pin)) begin Eq4 = 5.69e-15*exp(-0.0123*V(br_capvar)); salida = Eq4; end
if((Vg <= -V_pin) && (Vg >= -Vmax)) begin Eq5 = 6.689e-15*exp(-0.0299*V(br_capvar)); salida = Eq5; ITB = -0.0068*exp(-0.2583*V(br_resist)); salida1 = ITB; end end
if((flg == 1) && (lock1 == 1)) begin if((Vg <= -V_rest) && (Vg >= -Vmax)) begin Eq6 = 3.945e-15*exp(-0.0507*V(br_capvar)); salida = Eq6; ITB = -0.0068*exp(-0.2583*V(br_resist)); salida1 = ITB; end end
I(br_capvar) <+ ddt(salida); I(br_resist) <+ salida1 + CC*ddt(Vg) + I(br_capvar); end endmodule
