Jul 18th, 2024, 5:31am
mixed signal simulation problem (Read 159 times)
jsun
Apr 28th, 2009, 4:23pm
Hi, I am using cadence to do very simple mixed signal simulation. I created 6 shift registers by verilog and gave analog signal as input. Interface elements were successfully inserted. Netlists for analog and digital were created, but while running tran simulation in ADE, I could not get the plot. It stoped as below during the simulation without error message being reported.
Installed compiled interface for single_cpw.
Opening directory analog/input.ahdlcmi/ (770)
Installed compiled interface for bsource_1.
Notice from spectre during topology check.
   Only one connection to node `vdd!'.
Circuit inventory:
             nodes 10
         equations 32
            iprobe 9
               a2d 3
         capacitor 6
               d2a 6
           vsource 4
Transient Analysis `tran': time = (0 s -> 10 ns)
Here is the output from analog netlist,
// Generated for: spectre
// Generated on: Apr 28 14:57:09 2009
// Design library name: SAR_ADC_Layout
// Design cell name: top_tb
// Design view name: config
simulator lang=spectre
global 0 vdd!
include "~/c130nm/icfspectre.init"
// BEGIN Flat Interface Elements
// Flattened IE at /net10 uses port path 99999
// Flattened IE at /net5 uses port path 99998
// Flattened IE at /net11 uses port path 99997
// Flattened IE at /net9 uses port path 99996
// Flattened IE at /net7 uses port path 99995
// Flattened IE at /net8 uses port path 99994
// Flattened IE at /net4 uses port path 99993
// Flattened IE at /net6 uses port path 99992
// Flattened IE at /net3 uses port path 99991
// END Flat Interface Elements
// Library name: SAR_ADC_Layout
// Cell name: top_tb
// View name: schematic
// Inherited view list: SimMosfetStandard spectre verilog behavioral
//functional hdl system verilogNetlist auCmos_sch cmos_sch cmos.sch
//ads_schematic schematic auGate_sch auGate.sch gate_sch gate.sch
//extracted PLS_RCMIN_NoRC PLS_RCMIN_FSextract PLS_RCMIN_Mixed
//PLS_RCMIN_Cc_RCc PLS_RCMIN_R PLS_RCMIN_C PLS_RCMIN_RC PLS_RCMIN_Cc
//PLS_RCMIN_RCc PLS_RCTYP_NoRC PLS_RCTYP_FSextract PLS_RCTYP_Mixed
//PLS_RCTYP_Cc_RCc PLS_RCTYP_R PLS_RCTYP_C PLS_RCTYP_RC PLS_RCTYP_Cc
//PLS_RCTYP_RCc PLS_RCMAX_NoRC PLS_RCMAX_FSextract PLS_RCMAX_Mixed
//PLS_RCMAX_Cc_RCc PLS_RCMAX_R PLS_RCMAX_C PLS_RCMAX_RC PLS_RCMAX_Cc
//PLS_RCMAX_RCc PLSimported LPEimported PLS_DSPF_INCLUDE ahdl veriloga
C3 (net8 0) capacitor c=1f ic=0
C0 (net11 0) capacitor c=1f ic=0
C5 (net6 0) capacitor c=1f ic=0
C1 (net10 0) capacitor c=1f ic=0
C4 (net7 0) capacitor c=1f ic=0
C2 (net9 0) capacitor c=1f ic=0
V4 (net3 0) vsource type=pulse val0=0.0 val1=1.2
V3 (net5 0) vsource type=pulse val0=0.0 val1=1.2
V2 (net4 0) vsource type=pulse val0=0.0 val1=1.2
V5 (0 0) vsource dc=0 type=dc
V0 (vdd! 0) vsource dc=1.2 type=dc
// BEGIN Hierarchical Interface Elements
_ie99991 (net3 0) MOS_a2d dest="99991" timex=1m vl=0.5 vh=0.7
_ie99992 (net6 0) MOS_d2a src="99992" fall=50p rise=50p val1=1.2 val0=0
_ie99993 (net4 0) MOS_a2d dest="99993" timex=1m vl=0.5 vh=0.7
_ie99994 (net8 0) MOS_d2a src="99994" fall=50p rise=50p val1=1.2 val0=0
_ie99995 (net7 0) MOS_d2a src="99995" fall=50p rise=50p val1=1.2 val0=0
_ie99996 (net9 0) MOS_d2a src="99996" fall=50p rise=50p val1=1.2 val0=0
_ie99997 (net11 0) MOS_d2a src="99997" fall=50p rise=50p val1=1.2 val0=0
_ie99998 (net5 0) MOS_a2d dest="99998" timex=1m vl=0.5 vh=0.7
_ie99999 (net10 0) MOS_d2a src="99999" fall=2n rise=3n val1=1.2 val0=0
// END Hierarchical Interface Elements
   digits=5 cols=80 pivrel=1e-3 ckptclock=1800 \
   sensfile="../psf/sens.output" checklimitdest=psf
tran tran stop=10n errpreset=liberal ic=node cmin=1f write="spectre.ic" \
   writefinal="spectre.fc" annotate=status maxiters=5
finalTimeOP info what=oppoint where=rawfile
saveOptions options save=all pwr=all currents=all
Re: mixed signal simulation problem
Reply #1 - May 1st, 2009, 6:04am
I was convinced I'd answered this question somewhere, but I couldn't spot where...
Ah, just found it. It was on this forum - a rather similar question - are you two posters related?
http://www.designers-guide.org/Forum/YaBB.pl?num=1239285818/0#0
jsun
Reply #2 - May 1st, 2009, 3:25pm
Hi Andrew,
Thanks for the reply! I am not related with the poster you mentioned.
I read the document from MOSIS again about the technology, it seems that I cannot run this mixed signal simulation because the digital part spice netlists are not provided, but in black boxes.
Am I right?
