Jul 17th, 2024, 11:32pm
Why ADC output mid-code is not 2^(N-1)? (Read 2626 times)
seetoo
Apr 29th, 2009, 12:23am
Testing my 10bit pipelined ADC,(SMIC 0.18 process)
when diff input both connect dc commen input voltage(0.9V), the output code is not 511.
and the output code in 3 Evaluation Board is different respectively(1# is 485,2# is 540, 3# is 604).
It may because offset of opamp ,but should not so large(about 50mV).
So ,what else may cause the code excursion?
Berti
Re: Why ADC output mid-code is not 2^(N-1)?
Reply #1 - Apr 29th, 2009, 5:47am
Hi Seetoo,
Apart from the large offset the ADC performance is ok (INL, DNL)?
Cheers
Reply #2 - May 1st, 2009, 5:21am
There are a lot of possible causes I can think of, but I think the first thing is to see what the overall transfer function is - effectively what the INL and DNL is, as Berti suggests.
