Jul 18th, 2024, 11:20am
hspice simulator .probe v(*) output hiearchy all signals (Read 728 times)
neoflash
Mixed-Signal
Designer
Apr 29th, 2009, 12:03pm
How we can control it to just the top level specified.
such as .probe v(*) stops at top level
.probe v(x1.*) stops at block x1's top level?
spiceoracle
USA
Re: hspice simulator .probe v(*) output hiearchy all signals
Reply #1 - May 7th, 2009, 3:24pm
You can use
.option POSTTOP
to output only the node voltages and source currents at the top level of the circuit hierarchy.
You can use:
.option POSTLVL=n
If you want to output only the node voltages and source currents at a specific level of hierarchy specified by n.
One caution, the POSTTOP and POSTLVL options will be ignored if
.option PROBE
is also in the netlist.
