Jul 18th, 2024, 7:20am
Monte Carlo Similulation in ADE XL (Read 2610 times)
Fadi
Apr 30th, 2009, 10:16pm
I was trying to figure out how to run a monte carlo simulation in ADE XL. Can some one help me with this or point to a good tutorial on the subject.
Thnx
Re: Monte Carlo Similulation in ADE XL
Reply #1 - May 1st, 2009, 5:37am
Did you try reading the manual?
With IC612/IC613 you should be able to either invoke "cdnshelp" from the command line, or use the Help menus in the tools to navigate the help system.
Worst case, take a look at <ICinstDir>/adexl/adexl.pdf
In the version I looked at (latest IC613 ISR), Chapter 7 is "Performing Monte Carlo Analysis".
