Aug 16th, 2024, 6:58am
analysis type "static" not recognized (Read 381 times)
aaron_do
May 06th, 2009, 1:18am
this was my first try on creating a verilog-a model. I wanted to create a switch which is on for dc operating point type analyses such as dc, pss and the dc operating points of ac, sp, noise etc.
The code I used is based on the code given by pancho_hideboo in a previous post. Anyway this is the code i used.
Quote:
`include "constants.vams"
`include "disciplines.vams"
module analysis_switch(vp,vn);
inout vp, vn;
electrical vp, vn;
analog begin
 if( analysis("static"))
   V(vp, vn) <+ 0.0;
 else
   I(vp,vn) <+ 0.0;
end // analog
Unfortunately, the simulator doesn't seem to recognize the analysis type "static" as the switch is not closed when I use dc analysis. I wanted to double check so after a bit of experimenting i found that I could simply type in the CIW,
simulator('spectre)
analysis("static")
and it came up with the following message
Quote:
Invalid analysis type: static. Valid choices are tran(ac dc
noise xf sp spss pss pdisto spac spnoise spxf pac pnoise
pxf). Use ocnHelp('analysis) for more information.
So on inspection we can see that the analysis type "static" is not on the list. However, when i typed in analysis("ac") it gave me the exact same warming even though analysis type "ac" is on the list.
I'm totally lost here. Does anybody know how I can fix this. I need to either create the switch in another way, or fix the setup issue which seems to exist.
thanks,
Aaron
Re: analysis type "static" not recognized
Reply #1 - May 6th, 2009, 7:23am
"static" has been in the LRM for years, so I'm pretty sure your simulator should support it.  Note that the simulator itself doesn't have an analysis by that name, but the Verilog-A compiler/interpreter is supposed to understand "static" to mean dc, op-pt preceding ac, etc.
What version are you using?  What did you use to test it?  I put your module, a resistor, and a voltage source in series, and got the right answer.
aaron_do
Reply #2 - May 6th, 2009, 7:36am
thanks for the reply. Sorry i really don't pay too much attention to the inner workings of the software so i'm not too sure about all the answers.
So believe i'm using cadence version IC5141USR5. Is that the version you're asking about? So i assume the dc voltage was able to propagate through the switch right? It isn't working for me. Furthermore if I change line 9 to
if( analysis("dc", "static"))
it still doesn't work. Isn't the "," sign supposed to act as an OR function? Note that if I do
if(analysis("dc"))
then the switch works. However, that will not work for the operating point calculated in the ac analysis.
thanks,
Aaron
P.S.  Is it possible that some component of the software hasn't been properly installed? If so where would I start looking? thanks!
Reply #3 - May 6th, 2009, 11:49am
spectre -W is the subversion info for the simulator, but the IC version is good enough to tell me that you're using a rather old version.  On the other hand, we have a 5.10 version of Spectre, and it works for me.  I don't think there's any installation problem that would cause this problem.
Yes, the comma is supposed to act as an OR.  You could try
 if (analysis("dc") || analysis("static") )
Did you try a very simple netlist?
aaron_do
Reply #4 - May 6th, 2009, 6:38pm
Hi Geoffrey,
it is unable to work for a simple netlist. I used the same netlist as you did: a voltage source the analysis_switch and a resistor. The current does not flow through the switch for either ac or dc analysis. Seems to be unable to recognize the analysis type "static". My version of spectre is 6.1.1.133.
When I use
the analysis("dc") part works, but not the analysis("static").
thanks for the help,
Aaron
Paul Floyd
France
Reply #5 - May 7th, 2009, 5:10am
Hi
The 2.3 LRM says that ac, dc, noise, tran, ic, static and nodeset should be supported, plus any other simulator-specific options.
Paul
aaron_do
Reply #6 - May 7th, 2009, 5:28am
Hi Paul,
is there any way to confirm whether they are supported in my simulator? By the way what is the 2.3 LRM?
thanks,
Aaron
Reply #7 - May 8th, 2009, 7:00am
LRM means (Verilog-AMS) Language Reference Manual.  The latest is 2.3.  "static" has been in since at least 2.1, which is much older than your version of Spectre.  I'd really be surprised if it is a simulator problem.
aaron_do
Reply #8 - May 8th, 2009, 8:10am
Could it be a setup problem with the verilog simulator?
Reply #9 - May 11th, 2009, 7:55am
SourceLink solution number 1837470 says to use "static" ... for version 4.4.3.
Can you change versions at all -- either backwards or forwards?  Can you send the test case to Cadence?
Paul Floyd
France
Reply #10 - May 12th, 2009, 5:09am
aaron_do wrote on May 7th, 2009, 5:28am:
Hi Paul,
thanks,
Aaron
Hi
It depends on the simulator I guess. Mentor Graphic's [my employer] ADVance MS will print a warning at compile time if the string is not one of the recognized ones.
Paul
aaron_do
Reply #11 - May 12th, 2009, 11:45pm
Thanks for all the help guys. I managed to get the code working by switching to MMSIM621 from MMSIM611. Not sure why that worked but anyway...
Aaron
Reply #12 - May 29th, 2009, 12:53am
I'm wondering where you're testing this. In the very first post you talked about typing:
analysis("static")
in the CIW. Well, that's not Verilog-A that's SKILL (or OCEAN). So the analysis function there is for setting up an analysis in an OCEAN script. There's no such analysis as "static" so it's hardly surprising that doesn't work.
I dont' know why analysis("static") wouldn't work in a VerilogA model in spectre; this has been supported for as long as I can remember.
Andrew
aaron_do
Reply #13 - May 29th, 2009, 1:55am
Hi Andrew,
I guess my experimenting by typing into the CIW was not correct. I'm not at all familiar with SKILL (or OCEAN) so I can't really comment on your point. Either way the cell was not working. I was told that there are some bugs in our version of MMSIM611. When I switched to MMSIM621 the cell worked.
btw I actually wanted to learn some basics about SKILL or OCEAN just to get an idea of what it is. Do you know any useful resources?
thanks,
Aaron
Reply #14 - Jul 10th, 2009, 7:05am
The best thing for OCEAN is to attend a Cadence OCEAN training class (OK, I'm biased, because I wrote the class).
But otherwise you could look at the OCEAN Reference in the installation:
 <ICinstDir>/doc/oceanref/oceanref.pdf
And also the SKILL Language User Guide:
 <ICinstDir>/doc/sklanguser/sklanguser.pdf
Or use cdsdoc (or cdnshelp if using IC61) to read these documents.
