Jul 16th, 2024, 8:18pm
how to calculate cascade NF using SpectreRF? (Read 8002 times)
mydreamhouse
May 06th, 2009, 10:05am
if i simulate the lna and mixer separately using Pnoise analysis, but the cascade NF is not simple from Friis equation, which is because of noise folding effects from sidebands. so, how to calculate cascade NF with a mixer?
View Profile mydreamhouse   IP Logged
Re: how to calculate cascade NF using SpectreRF?
Reply #1 - May 6th, 2009, 10:39am
It seems you can't understand the following at all.
http://www.designers-guide.org/Forum/YaBB.pl?num=1240246880
mydreamhouse wrote on May 6th, 2009, 10:05am:
Calculate NF of cascaded system based on definition of NF without using Friis's equation.
If you understand NF correctly, it is no problem at all even if there are many noise folding effects from sidebands.
Even if frequency conversion blocks are included in cascaded system, calculation of total NF is very straightforward as far as we treat their input/output characteristics as linear relation.
Just cumulation of folding noises.
Here you have to know conversion gain of all sidebands which you have interest in as well as conversion gain of desired signal.
« Last Edit: May 6th, 2009, 2:44pm by pancho_hideboo »
mydreamhouse
Reply #2 - May 9th, 2009, 1:03am
thank you,pancho_hideboo
i calculate the NF(F) as follows:
first, i simulate LNA with matched input and load of mixer input impedance,  the ouput noise at mixer input is calculate by F and GT of phased noise analysis.
second,  the mixer is simulated with 50ohm port and 50ohm matching resistor without noise. so the output noise at mixer output is calculate in the same way as LNA
last,  F is calculate at mixer output as
F=(Noise from LNA and input 50ohm port + Noise from mixer)/(KTB*RS*GT^2)
where B=1HZ, RS=50Ohm GT is the transducer gain from LNA input to Mixer output.  LNA and Mixer are on-chip connected. Mixer output is also on-chip connected with next stage.
what wrong with above method?
the cacade F is smaller than that of direct combination of LNA and Mixer. but if i cascade two LNA. the cascade F of two LNA is well match with the result of  direct simulaiton.
mydreamhouse
Reply #3 - May 9th, 2009, 1:04am
where phased noise is Pnoise of Spectre RF
Reply #4 - May 9th, 2009, 3:10am
mydreamhouse wrote on May 9th, 2009, 1:03am:
What do you mean by "matched input impedance" ?
What is your definition of Gain for LNA ?
mydreamhouse wrote on May 9th, 2009, 1:04am:
What is "phased noise" ?
Even if you mean "phase noise", why do you need "phase noise" in evaluation of output noise for LNA ?
What do you mean by "50ohm matching resistor" ?
How do you calculate "Noise from LNA and input 50ohm port" ?
Show me equations you used.
How do you calculate "Noise from mixer" ?
What values of Gain for "RF->IF" and "Image->IF" are ?, here I assume spurious receiving point is only primary image.
Your denominator is for a definition of conventional SSB_NF.
Do you understand SSB_NF, DSB_NF and ASB_NF correctly ?
See http://www.designers-guide.org/Forum/YaBB.pl?num=1239925339
Nothing is correct. Cheesy
First what NF do you get for "LNA+Mixer" in simulation, SSB_NF or DSB_NF ?
Do you understand various voltage gain definitions correctly.
  Conventional Voltage Gain(=Vout/Vin).  Gain by Direct Plot of PSP is this definition.
  Gain definition of Direct Plot is same for PAC, PXF and Pnoise, which is not Vout/Vin.
  S21 is another Voltage Gain.
  Sqrt(Transducer Gain)
See http://www.designers-guide.org/Forum/YaBB.pl?num=1237656418
See http://www.designers-guide.org/Forum/YaBB.pl?num=1215827287/3#3
Again, do you understand SSB_NF, DSB_NF and ASB_NF correctly ?
« Last Edit: May 9th, 2009, 9:28am by pancho_hideboo »
mydreamhouse
Reply #5 - May 9th, 2009, 4:51am
LNA input is matched with a 50ohm port. the output noise from 50ohms port and LNA at LNA output  is :
N=F*KTB*Rs*GT^2   (V^2/HZ)
where F is SSB noise factor, B=1HZ, Rs=50ohm GT is transducer gain measured by Pnoise analysis, not conventional gain.
the SSB F at mixer output is calculated by N*AV^2, where AV is conventional gain from LNA output to Mixer output.
are these correct?
Reply #6 - May 9th, 2009, 4:59am
mydreamhouse wrote on May 9th, 2009, 4:51am:
"Transfer Function" in "Direct Plot Form for Pnoise of Cadence Spectre" is not "Transducer Gain".
Do you understand "Transducer Gain" correctly ?
And you can't define SSB_NF for LNA.
However these are not so serious misunderstanding.
are these correct?
Again, nothing is correct very completely. Cheesy Cheesy
Again, do you understand "Transducer Gain" correctly ?
Generally GTtotal is not equal to a simple multiplication of GT1 and GT2.
Here I define like followings.
  GT1 is a transducer gain of LNA with ZS1 and ZL1 as source and load impedances.
  GT2 is a transducer gain of Mixer with ZS2 and ZL2 as source and load impedances.
  GTtotal is a transducer gain of LNA+Mixer with ZS and ZL as source and load impedances.
If the following conditions are satisfied,  GTtotal will be equal to a simple multiplication of GT1 and GT2.
     ZS=ZS1,      ZL=ZL2
     ZL1=Zin2,      ZS2=Zout1
Here Zin2 is an input impedance of Mixer, Zout1 is an output impedance of LNA.
Do you satisfy this condition ?
However this is not so serious misunderstanding.
Your most serious misunderstanding are calculations of "Noise from LNA and input 50ohm port" and "Noise from mixer".
(1) Do you understand "Spurious Receiving of Mixer" ?
(2) What values of Gain for "RF->IF" and "Image->IF"  are ?
   Here I assume spurious receiving point is only primary image.
(3) Does your mixer have image rejection ability ?
Did you surely and correctly evaluate your Mixer by using PSS/PXF Analysis of Cadence Spectre ?
http://www.designers-guide.org/Forum/YaBB.pl?num=1236016393
All incomplete knowledges are always useless. Cool
I'm not kind and patient enough for correcting all your misunderstandings which are too many.
Other people who are very kind and patient might help you.
« Last Edit: May 9th, 2009, 12:17pm by pancho_hideboo »
