mydreamhouse wrote on May 9th, 2009, 4:51am:LNA input is matched with a 50ohm port.
the output noise from 50ohms port and LNA at LNA output is :
N=F*KTB*Rs*GT^2 (V^2/HZ)
where F is SSB noise factor, B=1HZ, Rs=50ohm
GT is transducer gain measured by Pnoise analysis, not conventional gain.
"Transfer Function" in "Direct Plot Form for Pnoise of Cadence Spectre" is not "Transducer Gain".
Do you understand "Transducer Gain" correctly ?
And you can't define SSB_NF for LNA.
However these are not so serious misunderstanding.
mydreamhouse wrote on May 9th, 2009, 4:51am:the SSB F at mixer output is calculated by N*AV^2, where AV is conventional gain from LNA output to Mixer output.
are these correct?
Again, nothing is correct very completely.
mydreamhouse wrote on May 9th, 2009, 1:03am:last, F is calculate at mixer output as
F=(Noise from LNA and input 50ohm port + Noise from mixer)/(KTB*RS*GT^2)
where B=1HZ, RS=50Ohm
GT is the transducer gain from LNA input to Mixer output.
Again, do you understand "Transducer Gain" correctly ?
Generally GT
total is not equal to a simple multiplication of GT
1 and GT
2.
Here I define like followings.
GT
1 is a transducer gain of LNA with Z
S1 and Z
L1 as source and load impedances.
GT
2 is a transducer gain of Mixer with Z
S2 and Z
L2 as source and load impedances.
GT
total is a transducer gain of LNA+Mixer with Z
S and Z
L as source and load impedances.
If the following conditions are satisfied, GT
total will be equal to a simple multiplication of GT
1 and GT
2.
Z
S=Z
S1, Z
L=Z
L2 Z
L1=Z
in2, Z
S2=Z
out1Here Z
in2 is an input impedance of Mixer, Z
out1 is an output impedance of LNA.
Do you satisfy this condition ?
However this is not so serious misunderstanding.
Your most serious misunderstanding are calculations of "Noise from LNA and input 50ohm port" and "Noise from mixer".
(1) Do you understand "Spurious Receiving of Mixer" ?
(2) What values of Gain for "RF->IF" and "Image->IF" are ?
Here I assume spurious receiving point is only primary image.
(3) Does your mixer have image rejection ability ?
Did you surely and correctly evaluate your Mixer by using PSS/PXF Analysis of Cadence Spectre ?
http://www.designers-guide.org/Forum/YaBB.pl?num=1236016393All incomplete knowledges are always useless. ![Cool Cool](https://designers-guide.org/forum/Templates/Forum/default/cool.gif)
I'm not kind and patient enough for correcting all your misunderstandings which are too many.
Other people who are very kind and patient might help you.
