Aug 16th, 2024, 8:24pm
About the Opamp in Integrator (Read 1751 times)
NiceFeng
May 07th, 2009, 4:24am
Hi, all,
  The picture shows a simple opamp-based integrator.
  Here it is required that wt >> 1/R1C1, is wt here referring to opamp with the loading effect of R1C1?
  Or when I design opamp, I want its wt >> 1/R1C1, should I just put a simple CL (which may be gate capacitance of its later blocks), or CL//(C1+R1)? or else?
  Thanks a lot!
Feng
buddypoor
Bremen, Germany
Re: About the Opamp in Integrator
Reply #1 - May 7th, 2009, 4:54am
wt (transit frequency) is the unity gain frequency of the (single pole) opamp (as listed in the data sheet) without any feedback circuitry .
