Jul 18th, 2024, 10:24am
exception handling in OCEAN (Read 2477 times)
analogue_guy
May 08th, 2009, 11:38am
Do you know how to make exception handling in Ocean?
If Calculator expressions, due to a reason, fail  (they result in NaN) usually stop the whole execution of the OCEAN script.
Any solution for that?
cheers
--AG
Re: exception handling in OCEAN
Reply #1 - May 8th, 2009, 9:44pm
Use "loadi()" instead of "load()".
Reply #2 - May 29th, 2009, 1:29am
The best solution is to check for return values of functions - for example, check that a data access function returned a value rather than nil - before using it in an expression.
That way you can handle errors gracefully rather than just causing an expression to fail. For example:
when(out=v("/out" ?result 'tran)
  fft=dft(out ...)
or:
if(out=v("/out" ?result 'tran) then
  fft=dft(out ...)
else
  printf("Transient analysis failed\n")
If for example the transient didn't run for some reason, v() will return nil, and so it won't try and do the dft on nil.
loadi() is one approach, but it's messy and doesn't really allow you to gracefully handle the errors.
