Aug 17th, 2024, 11:04am
Interpreting input logic busses as signed integers (Read 2833 times)
Alexander Eßwein
Erlangen, Germany
May 18th, 2009, 6:05am
I am modelling the behaviour of a DCO after Staszewski in Verilog-AMS.
As there are no integer type ports in Verilog, i have a bus of logic ports that i use to read the digital control word from.
I would like this port to behave like a signed integer input, but it only interprets the input as unsigned. How can I make the input behave like it is a signed integer port?
An example code of the DCO is attached.
Peruzzi
Re: Interpreting input logic busses as signed integers
Reply #1 - May 20th, 2009, 12:38pm
Hello Alexander,
I am guessing that the Staszewski case you are following is one in which he used VHDL (non AMS) and thus was limited to integer and real ports to carry analog information.
Since you are using Verilog-AMS you don't have that limitation.  You can use wreal signals and ports to carry your signed integers.
Hope this helps.
Bob P.
www.RPeruzzi.com
jbdavid
Reply #2 - Jun 1st, 2009, 5:53pm
use the keyword "signed" on the wire where you declare it
from 1364-2005 paragraph 12.3.3:
input_declaration ::=
input [ net_type ] [ signed ] [ range ] list_of_port_identifiers
if you used the signed keyword, the resulting integer will be treated just like a signed register.
`timescale 1ns / 1ps
`include "disciplines.vams"
module dco_1 (out, ps, ns, DCO_CONTROL);
    parameter real f0 = 100k from (0:inf);		// center frequency (Hz)
    parameter real kvco = 10k;			// gain (Hz/V)
    parameter real DCO_QUANT = 100p;		// period deviation per digital step
    input signed [7:0] DCO_CONTROL;			// digital control word
    input ps, ns;
    output out;
    electrical ps, ns;
    logic [7:0] DCO_CONTROL;
    reg out;
    logic out;
    real vin;
    real din;
    initial out = 0;
    always begin
	vin = V(ps, ns);
	din = DCO_CONTROL * DCO_QUANT;
	#((0.5e9 / (f0 + kvco * vin)) - ( din / 2))
	out = ~out;
jbdavid
Alexander Eßwein
Erlangen, Germany
Reply #3 - Jun 2nd, 2009, 4:04am
Thank you Guys, that very much did the trick!
