Aug 16th, 2024, 2:25am
noise_table question in the phase domain model of VCO (Read 2415 times)
lily
seattle
May 28th, 2009, 5:10pm
I want to use Ken's phase domain VCO model with noise_table function (as described in "Predicting the Phase Noise and Jitter of PLL-Based Frequency Synthesizers1").  My question is that how can I get the phase power density at each frequency? As the SpectreRF pnoise simulation results provide phase noise or output noise, can I directly use them or if not, is there any simple way I can get it? thanks!
Re: noise_table question in the phase domain model of VCO
Reply #1 - Jun 8th, 2009, 4:49am
You don't respond to our comments in the following.
http://www.designers-guide.org/Forum/YaBB.pl?num=1242929797
Have you resolved this issue ?
lily wrote on May 28th, 2009, 5:10pm:
I don't see the above document, but maybe you refer SΦ(f).
See the following.
http://www.designers-guide.org/Forum/YaBB.pl?num=1223659963/1#1
"pnoise" give Lssb(f).
"pnoise jitter" give SΦ(f).
Reply #2 - Jun 9th, 2009, 4:50am
