Aug 15th, 2024, 8:21am
about pss simulaiton for VCO (Read 2744 times)
lily
seattle
May 21st, 2009, 11:16am
Hi, I am trying to get the time domain steady state solution from the pss simulation for VCO. Is there any way that I can control the time points in the solution, say I want to get more time points than default solution. Thanks!
Re: about pss simulaiton for VCO
Reply #1 - May 22nd, 2009, 5:13am
lily wrote on May 21st, 2009, 11:16am:
What EDA vendor's simulator do you mean as "pss" ?
There are many simulators which have analysis called as PSS.
If you mean PSS analysis of Cadence Spectre, set "maxstep" parameter for PSS statement.
Enter "spectre -h pss" in Unix command line, you can see many parameters for PSS.
Reply #2 - May 22nd, 2009, 6:40am
Lily,
  Can you explain why you need more time points? If you think that
you want to lower the PSS noise floor, then  consider tightening the
error preset. For example use the conservative error preset if you are
using the default error preset. If you have an issue with small signal
analysis, then it might be best to set maxacfreq appropriately.
