Aug 17th, 2024, 5:17am
a question about linear pa. (Read 5188 times)
waseda-rfic
May 22nd, 2009, 1:54am
i am a new designner of linear pa. now, i have some problems in how to simulation the linearity of pa.
evm depicts the in-band distortion and acpr depicts the out-band distordion, what abot the am-am am-pm means? for in-band or out-band?
i find a strange problem, i design two pa. the simulation am-am and am-pm of the two pa are nearly similar. but the simulaton im3 has 10 dbc difference. why the im3 has so lage difference?
waseda-rfic
Re: a question about linear pa.
Reply #1 - May 22nd, 2009, 1:55am
thank you for your answers!
Reply #2 - May 22nd, 2009, 5:35am
waseda-rfic wrote on May 22nd, 2009, 1:54am:
AM/AM and AM/PM affects both in-band and out-band characteristics.
You described too few informations, so I can't say something surely.
The following is one possiblity for your case.
Maybe AM/AM characteristics of one PA is dominated by output nonlinearity rather than input nonlinearity.
On the other hand, AM/AM characteristics of the other PA is dominated by input nonlinearity.
waseda-rfic
Reply #3 - May 22nd, 2009, 7:44pm
thank you very much for your advise.  In my simulation, the AM-PM distortion is 4 degree at 16 dbm input (one stage pa) and IM3 is -10 DBc, in another PA (one stage pa) the  AM-PM distortion is 4 degree at 12dbm input and IM3 below -20 DBc. the two PA output p1dbs are nearly the same. so what causes this difference?
if as you says,Maybe AM/AM characteristics of one PA is dominated by output nonlinearity rather than input nonlinearity.On the other hand, AM/AM characteristics of the other PA is dominated by input nonlinearity.
i want to ask a question. in a cmos pa, whether the nonlinearity of Cgs dominats the input nonlinearity and the nonlinearity of Rds dominats the output nonlinearity and which is more important?
waseda-rfic
Reply #4 - May 23rd, 2009, 7:40am
pancho_hideboo wrote on May 22nd, 2009, 5:35am:
you mean input  nonlinearity is the  nonlinearity of pa?
waseda-rfic
Reply #5 - May 23rd, 2009, 6:54pm
hi pancho_hideboo
 thank s for your help!
waseda-rfic
Reply #6 - May 23rd, 2009, 7:33pm
hi pancho_hideboo
 thanks for your help!
by the way, do you know transforme based power combining? my simulation IM3 is asymmetry. may be some problems in my transforme?
Reply #7 - May 23rd, 2009, 9:30pm
waseda-rfic wrote on May 23rd, 2009, 7:33pm:
It seems you are trying to implement some IM3 canceling technique.
http://www.designers-guide.org/Forum/YaBB.pl?num=1243131271
So a frequency characteristics exists in your PA.
Asymmetrical IM3 is quite natural result when there is a frequency characteristics.
http://cp.literature.agilent.com/litweb/pdf/5989-8889EN.pdf
« Last Edit: May 23rd, 2009, 11:38pm by pancho_hideboo »
waseda-rfic
Reply #8 - May 25th, 2009, 1:44am
Hi pancho_hideboo
thanks!
