Jul 18th, 2024, 11:25am
Unity gain freq. and GBW (Read 2122 times)
kidman
May 25th, 2009, 9:16am
What are the cases when fu isn't the same as GBW?
raja.cedt
Re: Unity gain freq. and GBW
Reply #1 - May 25th, 2009, 10:22am
hi,
  why they should be equal?
  if bode plot is falling with 20dB/dec then A1/A2=F2/F1 here A1 and A2  are the two different points on the plot and F!,F2 are corresponding frequencies. So now ugb=dc gain*3db.This is the only one case your claim work.
regards,
Rajasekhar.
HdrChopper
Reply #2 - May 26th, 2009, 5:04pm
Hi Kidman,
In short, fu=GBW only if the system is a first-order one. If the system is of higher order then fu ≈ GBW only if there is a dominant pole (i.e. second and higher poles are far away from it). When 2nd pole is < 5×GBW then the difference between fu and GBW is noticeable.
Hope this helps
Tosei
Keep it simple
