raja.cedt wrote on May 26th, 2009, 2:28am:hi ,
what do you mean by 'i want the buffer only to change the impedance, but not the voltage level'. I understood that you need a buffer which has to work from vss to vdd/2.For this one i think pmos based op amp will work.
Rajasekhar.
sorry i didn't formulate the question very clearly. the following stage of the buffer has a quite low input impedance, so i use the buffer only as a driver, but i want the dc level of the buffer input and output to be the same.
how will the pmos opamp work? i assume you mean a noninverting configuration of the opamp. that means both inputs and output of the opamp have to go down to VSS. but the output level cannot be lower than one Vdsat above VSS.
