ic_engr wrote on May 26th, 2009, 9:19am:Hello All,
I heard there is a parameter which gives a feel for mismatches in a given CMOS technology. I believe its referred to as:
"Palgrim Constant."
Where would I find this and whats the symbol in Models for this ?
Any suggestions ?.
ic_engr
Pelgrom is the author you want to lookup. If you are lucky, the process you are using is characterized with a constant relative to his eqn.
