You don't respond to our comments in the following.
http://www.designers-guide.org/Forum/YaBB.pl?num=1242929797Have you resolved this issue ?
lily wrote on May 28th, 2009, 5:10pm:I want to use Ken's phase domain VCO model with noise_table function (as described in "Predicting the Phase Noise and Jitter of PLL-Based Frequency Synthesizers1").
As the SpectreRF pnoise simulation results provide phase noise or output noise, can I directly use them or if not, is there any simple way I can get it?
I don't see the above document, but maybe you refer
SΦ(f).
See the following.
http://www.designers-guide.org/Forum/YaBB.pl?num=1223659963/1#1"pnoise" give
Lssb(f).
"pnoise jitter" give
SΦ(f).
