Apr 25th, 2024, 11:50pm
How to represent a laplace system in matlab? (Read 7656 times)
neoflash
Mixed-Signal
Designer
Jun 01st, 2009, 8:13pm
How can I realize a system H(s)=a-b*e(-s*T) in matlab and view its group delay?
Neo
neoflash
Mixed-Signal
Designer
Re: How to represent a laplace system in matlab?
Reply #1 - Jun 1st, 2009, 8:44pm
H = tf([3 -1],[1 0],1e-9);
bode(H);
I found that I could represent it as z-tf. Then how can I calculate the group delay?
HdrChopper
Reply #2 - Jun 2nd, 2009, 6:30pm
Hi Neoflash,
Is not the delay constant here? It looks like a sampler transfer function, which has linear phase or constant delay....
Tosei
Keep it simple
raja.cedt
Reply #3 - Jun 4th, 2009, 4:42am
hi Neo ,
           could you please explain how did you represented your TF in mat lab? i didn't understand that reply you have given?
Rajasekhar.
neoflash
Mixed-Signal
Designer
Reply #4 - Jun 6th, 2009, 7:29pm
HdrChopper wrote on Jun 2nd, 2009, 6:30pm:
Hi Neoflash,
Tosei
For a system like: H(s)=a-b*e(-s*T). The group delay is not constant.
Reply #5 - Jun 8th, 2009, 1:57am
neoflash wrote on Jun 1st, 2009, 8:13pm:
a=3;
b=1;
Tdelay=1e-9;
H1=tf(a, 1);
H2=tf(b, 1);
set(H2, 'Outputdelay', Tdelay);
% s=tf('s');
% H2=b*exp(-s*Tdelay);
H1=ss(H1);
H2=ss(H2);
Hc=H1-H2;
freq=logspace(3, 10, 2000);
figure(1), bode(Hc, 2*pi*freq)
z=freqresp(Hc, 2*pi*freq);
x=real(squeeze(z));
y=imag(squeeze(z));
df=diff(freq');
dx=diff(x);
dy=diff(y);
freq=freq(1:length(freq)-1);
x=x(1:length(x)-1);
y=y(1:length(y)-1);
Gdelay=-(dy.*x-y.*dx)./(x.^2+y.^2)./(2*pi*df);
figure(2), semilogx(freq, Gdelay)
There is another method to evaluate Group Delay if you approximate Hc(s) as Hd(z).
You can  approximate Hc(s) as Hd(z) by using c2d().
Here Hc(s) means continuous time transfer function, Hd(z) means discrete time transfer function.
After getting Hd(z) as approximation of Hc(s), you can use grpdelay().
Following Hd(z) is Impulse-Invariant Discretization of Hc(s).
Hd=tf([a -b], [1 0], Tdelay);
See result of "doc c2d" in command window of MATLAB.
neoflash wrote on Jun 1st, 2009, 8:44pm:
bode(H);
« Last Edit: Jun 8th, 2009, 5:08pm by pancho_hideboo »
