Jul 18th, 2024, 5:27am
Any way to create schematic based on netlist? (Read 3341 times)
aaron_do
Jun 04th, 2009, 4:14am
I have some ESD pads which came with a single .cdl file which appears to be a compilation of all the netlists, as well as the layouts. Unfortunately, I'm not sure how to run LVS without the ESD pads in the schematic. So i'd like to know if there's an easy way to create a symbol which is basically just a black box with the .cdl file used as the netlist. I know all the pin connections for the ESD pad.
thanks,
Aaron
Berti
Re: Any way to create schematic based on netlist?
Reply #1 - Jun 4th, 2009, 8:04am
I think File-Import-Netlist View should do this, but I never used it. I just used Import Verilog, where a schematic view is generated from the verilog netlist.
aaron_do
Reply #2 - Jun 4th, 2009, 8:28am
Hi Berti,
could you give me a few more details on how to import the verilog netlist? Also how do i create a veilog netlist from the .cdl file?
thanks,
Aaron
salty
Austin, Tx
Reply #3 - Jun 5th, 2009, 9:31am
In cadence icfb, you can go to file->import->cdl
You will need a device-map file
Google and you can find information on it.  I have ran it in the past, and the map file was needed.
