aaron_do
I have some ESD pads which came with a single .cdl file which appears to be a compilation of all the netlists, as well as the layouts. Unfortunately, I'm not sure how to run LVS without the ESD pads in the schematic. So i'd like to know if there's an easy way to create a symbol which is basically just a black box with the .cdl file used as the netlist. I know all the pin connections for the ESD pad.
thanks, Aaron
