manodipan wrote on Jun 9th, 2009, 1:49am:Hi Vivek,
Lot of thanks for your reply......yes the variables are related by difference equations and may be they are not all independent....so now is there any way to force them to a common value,because it can be nonlinearly controlled(i.e. digital control)...and i actually want it to be generalised for multivariable system....any kind of suggestions are greatly welcome....
I would suggest using standard state-space techniques to describe the system and then using analysis techniques to find:
(a) the number of independent variables.
(b) the solution space, so that you may see whether or not it is possible to force all the variables to a common value, and if yes, then what that common value is allowed to be.
I assume that once you have worked out the above two, you may be able to use your binary-search based method to force the variables to a common value. I could not tell you more.
btw, your question actually does not appear to be explicitly related to analog design. Perhaps posting it on another forum would be more helpful.
Vivek
