Jul 20th, 2024, 6:32pm
Delta-Sigma Modulator, Feedforward or Feedback?? (Read 6118 times)
OpAmp
Jun 05th, 2009, 8:26am
I was wondering if anybody can introduce me a document comparing the feedback and feedforward structures of delta sigma modulators?
I have read the following two books (Delta-Sigma Data Converters by Norsworthy et al and Understanding Delta-Sigma Data Converters by Schreier and Temes) regarding this topic and couldn’t find the pros and cons of the two structures. For higher order delta-sigma DACs, I usually see feedforward structure is used, but I don’t quite understand why!!!
You comments are really appreciated.
OpAmp Smiley
Berti
Re: Delta-Sigma Modulator, Feedforward or Feedback??
Reply #1 - Jun 23rd, 2009, 3:37am
I try to give you a brief overview:
Advantages of Feedforward compared to Feedback: Lower signal swing at the output of the integrators (beneficial for amplifier design), larger first loop filter coefficient (better noise suppression than feedback structure), single DAC only, and depending on the implementation the feedforward structure might recover from instability without additional circuitry.
Disadvantages: The summing node in front of the quantizer.
In general I think that the lower signal swing is the main motivation why feedforward structures are preferred nowadays.
Cheers
Sumit Adhikari
Reply #2 - Aug 14th, 2009, 1:08am
Both of them has completely different usage as per as frequency domain is considered.
in feedback topology you introduce conjugate zeros in your transfer function as a result a low pass
transfer function (say in feedforward SDM) changes itself into a bandpass (feedback)
transfer function.
Lower or higher signal swing is an architectural design issue and has nothing to do
with topology. The usage of the input signal swing is decided by the choice of coefficients.
Please go through book "Data Converters" by Franco Maloberti
Sumit
« Last Edit: Aug 14th, 2009, 6:20am by Sumit Adhikari »
boa
Reply #3 - Aug 18th, 2009, 7:21am
Sumit,
I believe you misunderstood the question: the discussion here is about 2 different architectures  (feedback or feedforward) of SDM with low-pass NTF. Bandpass SDM is completely a different story..
Berti
Reply #4 - Aug 18th, 2009, 10:47pm
Yep Boa.
Sumit, read the paper following paper: J.Silva et al., "Wideband low-distortion delta-sigma ADC topology", Electronics Letters.
Cheers
vivkr
Reply #5 - Aug 20th, 2009, 3:00am
Berti wrote on Aug 18th, 2009, 10:47pm:
Yep Boa.
Cheers
Ah! but that is an Electronics Letters paper, a fat chance that anyone has a subscription to that one. So get it from the source directly:
http://web.engr.oregonstate.edu/~moon/research/files/el_jun07_01.pdf
Best regards,
Vivek
P.S.: There is also a lot of other useful stuff on this page. Just look around.
