Really? I find this rather surprising.
I'd like to understand how you're "probing" these nodes (what's the syntax in your file).
There should be no need to customize anything. You could run in "batch" mode (which will remove these +mps... args), but I can't see how that would help. In the CIW before starting ADE, do:
envSetVal("spectre.envOpts" "controlMode" 'string "batch")
But better to understand the root problem.
What spectre and IC subversions are you using (look in the spectre output file, and at Help->About in the CIW)?
