Jul 16th, 2024, 4:54pm
Deleting CDF Parameters by using SKILL script (Read 3983 times)
analogue_guy
Jun 25th, 2009, 7:38am
Could you help me how to delete CDF parameters by using SKILL script. I have found the cdfDeleteParam() command, but how could I tell it to delete let us say only the ads or spectre or ams properties (in the simInfo) or only the netlistProcedure parameter.
I did not manage to figure it out :-$.
Cheers,
Haydar
Portland, OR
Re: Deleting CDF Parameters by using SKILL script
Reply #1 - Jun 30th, 2009, 4:47pm
You can use cdfFindParamByName() to get the desired CDF parameter and then delete it using cdfDeleteParam().
Alternatively, you can use cdfDump() which will create a text file and then manipulate its contents with a script (Perl etc.) and load back the modified CDFs.
-Haydar
