Jul 17th, 2024, 11:21pm
a problem in Doherty Power Amplifier. (Read 4353 times)
waseda-rfic
Jun 10th, 2009, 11:00pm
the peak amplifier in Doherty PA should exhibits a high output impedence when it is off.  but i find it hard to make it has a high output impedence. anyone has some experiences?
Re: a problem in Doherty Power Amplifier.
Reply #1 - Jun 11th, 2009, 12:46am
Hello, keio-rfic.
Try to use techniques such as active cascode connection or cascode bootstrap in cascode amplifier.
K.Bult and G.J.G.M.Geelen:"A Fast Settling CMOS Op Amp for SC Circuits with 90dB DC gain", IEEE JSSCC, vol.25, no.6, Dec. 1990.
waseda-rfic
Reply #2 - Jun 11th, 2009, 7:19pm
pancho_hideboo wrote on Jun 11th, 2009, 12:46am:
thanks for your help again.  active cascode and cascode bootstrap can increase the output impedence in low frequency. but i am not sure it is also effective in RF frequency as in 5 GHz? i see in the paper .they mainly use offset line or match network to increase the impedence. but in my simulation, i find hard to satisfy both load line and high output impedence using match network.  so i want ask which is better for improve the impedence?
waseda-rfic
Reply #3 - Jun 11th, 2009, 7:48pm
Reply #4 - Jun 15th, 2009, 1:19am
keio-rfic, don't do duplicate posts.
The following two are completely same.
      http://www.designers-guide.org/Forum/YaBB.pl?num=1244700012/2#2
      http://www.designers-guide.org/Forum/YaBB.pl?num=1244700012/3#3
waseda-rfic wrote on Jun 11th, 2009, 7:19pm:
It is effective. But it is not effective for capacitive component of output impedence.
i see in the paper. they mainly use offset line or match network to increase the impedence.
Both cascode amplifier and reactive impedance transformer using discrete LC or distributed lines are needed.
waseda-rfic
Reply #5 - Jun 16th, 2009, 2:18am
HI pancho_hideboo
thank you for your reply. I got it!!!
