Aug 15th, 2024, 12:31pm
Fingering a transistor ... (Read 2098 times)
somisetty
Jun 11th, 2009, 4:33am
what are the advantages of fingering a transistor in terms of circuit design?
I have transistors M1 and M2 with widths/lengths as W1/L1 and W2/L2 respectively.If there are connected in series together as shown in the figure.what would be the value of widths/lengths (W3/L3) of M3 transistor which is equivalent to M1 and M2?
raja.cedt
Re: Fingering a transistor ...
Reply #1 - Jun 11th, 2009, 5:23am
hi,
  very simple you will get less diffusion cap... roughly i remember it will be half of the original cap provided if your fingers are very high
  there i assumed that gates of both m1 and m2 are connected, in that case m2 will be in triode and if both w1 and w2 are equal then m3 size will be w1/(l1+l2), if they are not equal then i guess very big equation will come.
thanks,
rajasekhar.
