Aug 15th, 2024, 3:25pm
Serial flash current consumption (Read 1045 times)
baba_sanfur
Jun 11th, 2009, 11:55am
I plan to use FLASH memory in a project, and I'm concern about the current consumption of the serial FLASH.
With SST25VF512 (for example) the read current consumption is 10ma, at 20Mhz. I don't need to work in such speed - 400khz is more than I need.
How can I determine the read current consumption at ~500khz?
More ever, how will the write current consumption change at 500khz? (mfg clam for 30ma write current consumption, but doesn't say what is the speed)
Nir
