Aug 15th, 2024, 6:25pm
Which OTA architecture for this pipelined ADC (Read 2796 times)
kidman
Jun 11th, 2009, 3:32pm
I am to design an OTA for a pipelined ADC with 2.5 bits/stage.
These are the apparent specs of the OTA
Voltage swing = 1 Vp-p differential
Gain = 60db
GBW = 100MHz
PM=70 degrees
GM=10db
Current consumption = 300uA max
AnalogDE
Re: Which OTA architecture for this pipelined ADC
Reply #1 - Jun 11th, 2009, 4:44pm
telescopic or folded cascode, depending on your supply.
raja.cedt
Reply #2 - Jun 11th, 2009, 11:42pm
hi, you have to specify the load cap also, because you have around 300ua with this are you able to get required Ugb?  And getting 70db gain also difficult in one stage but with your current spec you should bound with single stage so better use cascode with gain boosting.I understood all specification derivation but how did you come up with required gain margin?
thanks,
rajasekhar.
kidman
Reply #3 - Jun 12th, 2009, 1:51am
1- I am using a 0.13u tech. Supply is 1.2v. Sorry for not mentioning that.
2- Actually there are still uncertainities concerning the exact value of the load cap. but I don't think it'll exceed 500fF.
3- Concerning the gain margin. I am part of a school project and making the specs isn't my task. My task is to take the specs and design the OTA.
AnalogDE
Reply #4 - Jun 12th, 2009, 8:19am
I think your supply is too low to do a cascoded one stage scheme.  go with a two stage miller OTA.  You will need to know what your load cap is, in order to compensate the amp.
