raja.cedt
hi, you have to specify the load cap also, because you have around 300ua with this are you able to get required Ugb? And getting 70db gain also difficult in one stage but with your current spec you should bound with single stage so better use cascode with gain boosting.I understood all specification derivation but how did you come up with required gain margin?
thanks, rajasekhar.
