Aug 16th, 2024, 6:27am
how to simulate PSR in an differential amplifier (Read 4736 times)
uu@uk
Jun 11th, 2009, 5:48pm
actually I am going to simualte how an differential amplifer reject the power supply induced jitter at the output using Spectre. One suggestion is to superimpose a sinusoid signal at the power supply and run transient simulation to check the crossing deviation at the output. However, it is time penalty.
Anyone has other methods by using PSS or PXF? Thanks.
raja.cedt
Re: how to simulate PSR in an differential amplifier
Reply #1 - Jun 11th, 2009, 11:18pm
hi,
  you can search there are many ports in here for PSRR. And  there is some test bench in http://www.designers-guide.com/Analysis .But try to apply pulse with rise time at the frequency of interest.
  Are you using diff amp for any oscillator?
thanks,
Rajasekhar.
uu@uk
Reply #2 - Jun 12th, 2009, 10:43pm
Hi Raja,
Thanks for your information. I found some useful discussions here. Actually the differential amplifier is not for any kind of osc. It is for a buffer chain.
raja.cedt
Reply #3 - Jun 13th, 2009, 7:04am
hi
  if you are not using diffamp for oscillator purpose then why your interested in o/p jitter?
rajasekhar.
uu@uk
Reply #4 - Jun 13th, 2009, 1:59pm
Hi Raja,
Sorry. Maybe I misled. It is an amplifier in the PLL based freqency synth. That is why I care about o/p jitter.
raja.cedt
Reply #5 - Jun 13th, 2009, 9:08pm
hi uu@uk,
             where you are using this amplifier? and how did you find jitter then (normally jitter means peak to peak variation in the time period).
Rajasekhar.
uu@uk
Reply #6 - Jun 14th, 2009, 11:45pm
Hi Raja,
I just insert the differentail amplifier before output buffer. Using the differential one but not CMOS inverter because it suppress lot of power supply noise and substrate noise induced jitter.
Do you mean how to simulate power supply noise induced jitter or device noise induced jitter? for the device noise induced jitter, you just can easily using "Pnoise" to get the jitter results. But for power supply noise induced jitter. it is kind of confused to me. I tried using transient simulation, but it is time penalty. Now I wanna convince myself to use PXF to achieve the jitter at the output. I am still working on it. If you are also still interested in this problem or you have any good suggestion. welcome to send me email by luvckt@live.com
Frank Wiedmann
Munich, Germany
Reply #7 - Jun 15th, 2009, 1:31am
Take a look at http://www.designers-guide.org/Forum/YaBB.pl?num=1224609785/13#13 and read (at least) reply #13 to #18 (please note that the thread has three pages).
