uu@uk
Hi Raja,
I just insert the differentail amplifier before output buffer. Using the differential one but not CMOS inverter because it suppress lot of power supply noise and substrate noise induced jitter.
Do you mean how to simulate power supply noise induced jitter or device noise induced jitter? for the device noise induced jitter, you just can easily using "Pnoise" to get the jitter results. But for power supply noise induced jitter. it is kind of confused to me. I tried using transient simulation, but it is time penalty. Now I wanna convince myself to use PXF to achieve the jitter at the output. I am still working on it. If you are also still interested in this problem or you have any good suggestion. welcome to send me email by luvckt@live.com
