Jul 19th, 2024, 12:37am
Maximum on-chip variation in temperature for SOC (Read 2862 times)
cmos.analogvala
India
Jun 11th, 2009, 11:19pm
What is the maximum variation in temperature of two IPs on a system on chip ?
It wud be great if someone can proveide reference for this ?
-CA
vivkr
Re: Maximum on-chip variation in temperature for SOC
Reply #1 - Jun 12th, 2009, 12:05am
I do not believe that there is any standard answer possible for that. Are you speaking of 2 different copies of the same circuit placed on a chip or 2 completely different kind of circuits?
The temperature depends on several factors like power consumption of a part, it's size, whether most of the power is burned in a few elements or overall, what sort of package you have, and also what other circuits are placed nearby and their power consumption etc. So, no general answer is possible.
Why do you want to know this by the way?
Vivek
cmos.analogvala
India
Reply #2 - Jun 13th, 2009, 9:33am
I have a signaling shcme for global interconnects where driver and receiver are placed far apart. I want to see the performance of the scheme under worst case temperature mismatch. Let's say in an SOC Tx is at FFT unit and Rx is near memory block. What is the worst case temperature difference on the chip ?
-CA .
Reply #3 - Jun 16th, 2009, 7:50pm
Hi CA,
I agree with Vivek. So it is difficult to have a standard answer now. But don't worry. Make your chip/system consume less power, use a package with good cooling system to reduce the temperature variation.
Yawei
cmos.analogvala
India
Reply #4 - Jun 17th, 2009, 9:54am
I just need a maximum possible number you might have seen. Say 10 degree, 20 degree or 50 degree C temperature variations you see ?
-CA
