Aug 16th, 2024, 2:25am
replacing the ideal tail current in a differential pair with active transistors (Read 3532 times)
salma shabayek
Jun 12th, 2009, 1:27am
Dear all,
I'm having a trouble in replacing the ideal tail current in the differential pair with an nmos current sourc transistors mirrored to an nmos diode connected transistor.
I did so by placing the nmos transistor with double the size of the nmos input transistor but I dont get amplification.
before placing the tail current I had large gain but now I dont..
so please if anyone knows what's the problem please tell me.
I also have another question ; since I'm working with 1uA current per branch and from using the current density charts and gm/id curves in Spectre I always get (W/L) ratio< 1
Is that acceptable???
thank you alooooooottttttttttttt
subgold
Re: replacing the ideal tail current in a differential pair with active transistors
Reply #1 - Jun 12th, 2009, 2:47am
it is because your dc biasing point of the input transistors are too low.
raja.cedt
Reply #2 - Jun 12th, 2009, 3:05am
hi,
   did you probe the tail transistor drain?i think it is  at very low hence tail transistor is in triode so degeneration. I am surprising how cum you are working with 1u, what you will get 1u?
rajasekhar.
oermens
Reply #3 - Jun 12th, 2009, 4:21am
In order to achieve IdsNM1=IdsNM4 you need
(W/L)NM1=(W/L)NM4
VgsNM1=VgsNM4
VdsNM1=VdsNM4
you are probably not meeting the last criteria. if you can spare the headroom, use cascode or wilson current mirror. refer to razavis analog book.
also I think it is difficult to achieve 1uA from tail transistor in saturation. you might have to consider weak inversion current mirror. but this suffers from poor matching... see this paper: http://ieeexplore.ieee.org/xpls/abs_all.jsp?arnumber=4263360
ic_engr
Reply #4 - Jun 12th, 2009, 8:36am
Salma,
What is your supply voltage.  What is the VT of the NM0 & NM8.?
You definitely need to raise the DC levels on the diff pair (NM0 & NM8). Remember, the lower the DC on the diff pair, the lower VDS will be on the current source NM4 in question.
More importantly, looking at the model names (n_12_hs130e), it seems you are using high speed devices, which will definitely suffer with poor output impedance thus excerbating your problem.
Good luck.
salma shabayek
Reply #5 - Jun 13th, 2009, 3:33am
ok ...thank you alll soooo muchhh
