Jul 17th, 2024, 11:23am
Pages: 1 2
Stability analysis for two stage CMOS Op Amp in Spectre (Read 1186 times)
Mohammed Omar
Jun 12th, 2009, 1:56pm
Hi All,
When designing a two stage CMOS Op Amp using Spectre, where is the best point to put the IPROBE when doing STB analysis? At the input of the 2nd stage or at the input of the first stage?
Frank Wiedmann
Munich, Germany
Re: Stability analysis for two stage CMOS Op Amp in Spectre
Reply #1 - Jun 15th, 2009, 1:51am
Do you see a difference in the results? Normally you shouldn't. If you do, please post your schematic.
Mohammed Omar
Reply #2 - Jun 15th, 2009, 5:45am
Yes, I notice a difference in both the phase and gain plots. What is most noticeable is that cutting at the input of the second stage I find the phase plot to start at (-180 degrees) and starts going "UP" to zero degrees.
Frank Wiedmann
Munich, Germany
Reply #3 - Jun 15th, 2009, 6:50am
Your circuit obviously has two loops, one from the output to the input of the first stage, and another one from the output to the input of the second stage. You must put the probe into a wire that breaks both loops when opened, so the position in your schematic is correct. For details, see the section "Applicability of Loop-Based and Device-Based Algorithms" of http://www.kenkundert.com/docs/cd2001-01.pdf, this is the article that describes the algorithm used by the stb analysis.
For a circuit with negative feedback, the phase of the loop gain is supposed to be -180 degrees at low frequencies in stb analysis. For details, see http://www.designers-guide.org/Forum/YaBB.pl?num=1124688329.
Mohammed Omar
Reply #4 - Jun 15th, 2009, 7:39am
Thanks a lot for your fast reply Frank.
The problem is not with the phase starting at (-180) or 180, but with the resulting phase plot; The STB analysis is not able to calculate the phase margin. Also the resulting phase plot shows the system to be unstable while transient simulations show that is stable with adequate phase margin.
Attached is the Bode plot for the behavioral model.
Frank Wiedmann
Munich, Germany
Reply #5 - Jun 15th, 2009, 10:57am
I don't think that the plot shows the system to be unstable. If you do a Nyquist plot (see http://en.wikipedia.org/wiki/Nyquist_stability_criterion) of the loop gain (the negative loop gain as calculated by the stb analysis), you will see that it encircles the point (-1 + j0) counterclockwise and not clockwise, so I don't think that there are any closed loop poles in the right half of the s-plane.
Always use the Nyquist stability criterion in case of doubt. You can find another example with slightly counterintuitive results at http://www.designers-guide.org/Forum/YaBB.pl?num=1182388268.
Mohammed Omar
Reply #6 - Jun 15th, 2009, 12:24pm
What makes me say its unstable is that in the Bode plot the gain at the phase cross-over point is about 30 dB. Isn't this enough to judge unstability? Also is this phase response normal or possible to be judged?
Frank Wiedmann
Munich, Germany
Reply #7 - Jun 15th, 2009, 11:33pm
No, it is not enough to judge instability. Use the Nyquist stability criterion in such unusual cases. The unusual behavior might be due to the fact that you have two loops or due to the component values in your models.
Reply #8 - Jun 16th, 2009, 9:29am
Mohammed Omar wrote on Jun 15th, 2009, 12:24pm:
See the following although your case is absolutely stable.
http://www.designers-guide.org/Forum/YaBB.pl?num=1190272820
RobertZ
the art of analog
San Diego, CA
Reply #9 - Jun 17th, 2009, 11:45pm
Frank Wiedmann wrote on Jun 15th, 2009, 10:57am:
Hi, wiedmann,
by saying the counter-clockwise encirclement of -1, do you mean the nyquist plot begins from real x-axis, and goes through the 1st, 2nd, 3rd quadrant and then torwards orgin? it never goes into the 4th quadrant?
Qubo
Robert
Frank Wiedmann
Munich, Germany
Reply #10 - Jun 18th, 2009, 1:34am
If you carefully look at http://en.wikipedia.org/wiki/Nyquist_stability_criterion, you can see that the Nyquist plot starts at the frequency -∞, not 0, and is always symmetric to the real axis.
Mohammed Omar
Reply #11 - Jun 18th, 2009, 4:30am
Thanks Frank,
I'm reading some literature about Nyquist plots and stability right now. Thanks a lot for your help and comments, it was quite useful.
One more question; In case I'm given a phase margin specifications, this means I must reside to the transient response? Or how to obtain the phase/gain margin from Nyquist plots?
Mohammed Omar
Frank Wiedmann
Munich, Germany
Reply #12 - Jun 18th, 2009, 5:53am
RobertZ
the art of analog
San Diego, CA
Reply #13 - Jun 18th, 2009, 11:30pm
Frank Wiedmann wrote on Jun 18th, 2009, 1:34am:
Hi, Frank,
You are right about the symmetry. After I sketched the Nyuist plot, I realized that there are two counter-clockwise encirclement of -1. To make Z = 0, p must be =2, which means the open loop has 2 poles in RHP. Is this right?
Robert
Robert
Frank Wiedmann
Munich, Germany
Reply #14 - Jun 18th, 2009, 11:48pm
Yes, I think this is right.
Pages: 1 2
