Aug 15th, 2024, 10:14am
Mixer or not (Read 2712 times)
microwaver118
Mixer or not
Jun 17th, 2009, 7:41pm
can anybody design a 3.5G Mixer with 15dBm iip3,16dB Conversion gain? can it be implemented in 0.13um CMOS 2.5V supply voltage?
Any tips will be welcome!
ACWWong
Oxford, UK
Re: Mixer or not
Reply #1 - Jun 18th, 2009, 9:22am
yes this seems like it can be done.... whether it can be done within the area and power budget is a different matter though.
microwaver118
Re: Mixer or not
Reply #2 - Jul 1st, 2009, 1:50am
Thanks for your reply!Now I 'm facing difficulties when designing Mixer. it arrouds tradeoff between iip3 & Voltage Gain. One type 9dB VG with 15dBm iip3 OR another type 14dB VG with 10dBm iip3. it seems there exist a Figure Of Merit maybe VG+iip3 for a specified technology,so we can evaluate if this technology fit for the specification, maybe a limited we can achieve.is that right?
ACWWong
Oxford, UK
Re: Mixer or not
Reply #3 - Jul 1st, 2009, 2:28am
Its usual that for a given power consumption that in the design of most circuits there is a trade off in linearity and gain, when gain is up, linearity goes down and vice versa (having said that there is usually noise included into this balancing act). This is true for mixers, and your results seems typical for a given topology at a given power consumption. If you are not making spec, then more power or a better design topology should do the trick. I don't believe your spec is fundamentally limited by process technology node.
