Aug 17th, 2024, 2:15am
Problem with my biasing scheme (Read 4195 times)
kidman
Jun 18th, 2009, 5:19am
I am trying to bias a telescopic amp with PMOS input pairs. I don't use ratioing (only for the tail current source). To achieve a high bias swing, I use the quarter size transistor method. What I get is that most of the supply is across the PMOS cascode transistor. I have attached the biasing scheme. Can you please take a look at it? And also I would be grateful if you could tell me how would you bias such an amp. Thanks
subgold
Re: Problem with my biasing scheme
Reply #1 - Jun 18th, 2009, 8:01am
where is your pmos input transistor of the amp?
why do you cascode two current sources (#16 and #17) together? then neither of these two current sources is working properly.
kidman
Reply #2 - Jun 18th, 2009, 9:12am
The arm on the right is the telescopic amp but only with one side shown
Transistor 17 is the tail transistor of the amp. I included it just to show how it is biased.
wave
Reply #3 - Jun 18th, 2009, 10:57am
This one made me think a bit.  I'm used to other structures.
Why is your gates of M8, M15, M14 on the source of the bias?
Take it up a Vgs. (down for Pmos).
kidman
Reply #4 - Jun 18th, 2009, 11:11am
This is the quarter size transistor method. You can read about it in grey&meyers book
wave
Reply #5 - Jun 18th, 2009, 1:45pm
kidman wrote on Jun 18th, 2009, 11:11am:
Gotcha.  Yeah, it's in there.  Usually I use the one a few pages later, "MOS high-swing current mirror with two input branchs" which has better input headroom.
Two transistors collapse into one, atleast 1/4 or smaller after Body Effects.
cheers,
Wave
AnalogDE
Reply #6 - Jun 18th, 2009, 2:30pm
Watch out for input common mode level -- if it's not set in the right place the output common mode will rail.  I suggest you drive both inputs and sweep the CM level until you get the amp in the high gain region (if you are free to change the CM level)
barry
CA
Reply #7 - Jun 21st, 2009, 10:53am
The current through M16 is less than the current through M10 because the voltage at the source of M10 is VDD and the voltage at the source of M16 is less.
The current through nmos source M13,M14 is equal to the current through M10. Thus the voltage at the drain of M14 goes low and most of the power supply voltage is across M15.
M16 is one of the opamp inputs, right? As jiesteve mentions, your common-mode input on the gate of M16 is too high.
