ViggoBiggo
Section 11.4.1. of the IEEE std 1364-2005 says: Statements within a begin-end block shall be executed in the order in which they appear in that begin-end block. Execution of statements in a particular begin-end block can be suspended in favor of other processes in the model.
Example (only to illustrate the uselessness of always statements):
always @(a) begin b = a; c = a; end
Here we have an always statement that does not contain any delays. The begin-end block will get executed in 0 time when activated.
I think most designers would expect "b" and "c" always to be equal. Maybe they'll change in different delta cycles, but after the simulation time is advanced they should be the same ... right? Otherwise, all behavioral code examples in all text books are wrong!
Now let's say "a" changes from "0"->"1", "b" is set to "1" and the simulator scheduler decides to suspend the process, it does something else that results in "a" going back to "0". Now when it comes back to the begin-end block (all in 0 time) it now assigns "0" to "c". And per your previous response (and I think you are right) the transition of "a" from "1" to "0" (the 2nd trigger) is ignored because it happen while the simulator was in the middle of the begin-end block. Thus we end up with "b" equal to "1" and "c" equal to "0".
Now obviously this only happens if 1) processing of the begin-end block is suspended -and- 2) "a" changes while the begin-end block is suspended -and- 3) triggers are ignored while processing of an always statement is suspended
If the always statement was re-triggered (on "a" going from "1" back to "0") we'd see a glitch on "b" (not different from real gates) but "b" and "c" would both be "0" (correct value) when the simulation time was advanced.
Thus my original question: Does a suspended always statement get re-triggered if a signal in its sensitivity list changes?
If the answer is NO then I believe always statements are TOTALLY useless per the example above with regard to modeling of combinatorial logic (even for DV).
And it does indeed look like the simulators from all the big EDA vendors work like illustrated above ... scary!!!
Likewise, if begin-end blocks w/o timing control aren't suspended we (RTL designers / DV engineers) wouldn't have a problem either ... but that is totally legal per the reference above.
I haven NOT be able to find it, but I 'd really like to know what the LRM (IEEE 1364-2005 ... I think the standard number has changed though) say about triggers that happens while an always statement is suspended ... could somebody point me to that section in the LRM ... that would be really great. Thanks a lot!
