Jul 19th, 2024, 10:35am
choosign filter (Read 4233 times)
smarty
choosign filter
Jun 18th, 2009, 11:21pm
Hi All,
 I am not sure if this has been already discussed in the forum, but I wanted to know from a given specs for filter how would we choose whether to implement using gm-C or opamp-RC.
what decides which one to use.
It might be basic but I was keen to know and if so how should I go about the task?.
SBR
View Profile smarty smarty   IP Logged
buddypoor
Bremen, Germany
Re: choosign filter
Reply #1 - Jun 19th, 2009, 1:26am
Ohhh smarty - another question would be much easier to answer.
There are several technologies and by far more than 20 different topologies to construct a lowpass filter. And the problem is - they  influence each other !
The choice depends on a lot of subjects/requirements:
frequency, order of the filter, tolerance requirements, cost, technlogy (lumped or integrated), tunability, with/without zeros, power consumption, supply voltages, .....
Sure that I forgot something.
In general, I would say that gm-C can be recommended for higher frequencies, for integrated technology and/or when tuning is required.
But, as you see there are several other aspects - and a general answer is certainly NOT possible and not appropriate.
smarty
Re: choosign filter
Reply #2 - Jun 19th, 2009, 2:25am
Hi Mr. Buddy,
 Thanks for the reply.
But my understanding was, gm-C would suffer from linearity perspective( which is one of the important criteria for filter) than the other counterpart, then in that case why is gm-C preferred, for sure people suggest that for high frequency ( I assume the other poles of op-amps) could affect the filter performance.
In general, what I really after was. Say we have a specs for Cut-off frequency, dynamic range, noise specs, group delay specs ( just to name a few) and this is for Integrated filter and I am not really caring for power, then how really should I go through the process.
Should I go from books for any approximation( butterworth, bassel, chebeshev...) or any other way.
Thanks.
SBR
buddypoor
Bremen, Germany
Re: choosign filter
Reply #3 - Jun 19th, 2009, 2:49am
smarty wrote on Jun 19th, 2009, 2:25am:
........But my understanding was, gm-C would suffer from linearity perspective( which is one of the important criteria for filter) than the other counterpart, then in that case why is gm-C preferred, for sure people suggest that for high frequency ( I assume the other poles of op-amps) could affect the filter performance.
...... Say we have a specs for Cut-off frequency, dynamic range, noise specs, group delay specs ( just to name a few) .......
At first, You are right in saying that dynamic properties/linearity are other aspects I forgot to mention.
At second, my understanding of your question now is that you are not sure about the several steps in designing a filter.
Therefore, at first the approximation has to be selected - and this depends on your damping requirements expressed by frequencies and corresponding damping.
Here you have several alternatives e.g. with or without zeros. On the other hand, this choice influences also the filter degree which is required - and also the delay characteristics (if they play a role). You see, it ends in a compromize between several conflicting aspects.
But thatīs normal live for analog engineers and makes a single and final  answer to your question difficult.
buddypoor
Re: choosign filter
Reply #4 - Jun 21st, 2009, 6:33pm
Two questions are being asked here, and I see them being dumped into a single question.
Question 1 - What is my pole/zero placement necessary to get the frequency response desired?
Question 2 - What is the circuit level implementation needed to implement my pole/zero placement?
First question can get answered with some some simulation tools, matlab, or even (its a little awkward, but do-able) on an Excel spreadsheet. That or a good filter book (Zevrev is the classic) will get that question answered.
Second question is an issue of frequency and linearity. - High frequency filters (GHz land) tend to get done with passive methods (all LC sections or microwave with resonance cavities and similar.) As you come down in frequency and put it inside a chip, gmC filters get used in the 50MHz to 1GHz region. (YMMV) and linearity issues are a concern, but it can be controlled in a similar manner to how one deals with linearity in an RF design. As you come lower in frequency (200MHz to DC) you tend to use op-amp and RC methods. Linearity is much less of an issue because the high open loop gain of the op-amps will make for good linearity when in a closed feedback system.
As an aside, tuning of a gmC filter needs to be updated frequently due to thermal variance (even with compensation) and op-amp RC systems tend to be a bit more set once and then retune on the next power up.
Tuning systems tend to be a big part of the design effort so don't forget to budget time for that.
Jerry
buddypoor
Bremen, Germany
Re: choosign filter
Reply #5 - Jun 21st, 2009, 11:46pm
Quote loose-electron: First question can get answered with some some simulation tools, matlab, or even (its a little awkward, but do-able) on an Excel spreadsheet. That or a good filter book (Zevrev is the classic) will get that question answered.
Instead I recommend one of the powerful filter design programs available for download from the web. They are very easy to use and - more than that - give some hints for realization (mostly RC).
Although ZVEREV is the classical one, I would not recommend it.
It is too detailed. When you donīt intent to become a specialist in filter design, use instead filter software or some other introductory papers.
But, be aware that no single and final answer to your design problem is possible. Itīs always a compromize between conflicting requirements.
smarty
Re: choosign filter
Reply #6 - Jun 22nd, 2009, 5:04am
 Thanks for your inputs, will do some work and will share my findings with you all..
SBR
