Jul 17th, 2024, 5:43pm
Antenna Design Textbook - Small Format, Planar (Read 4796 times)
Jun 20th, 2009, 12:56pm
Hey all - I am looking for some suggestions on a textbook on antenna design, small format antennas, planar, pcb type of antennas.
Practical considerations in design, geometry, optimization, are important, not a course in EM design.
My specifc needs are for a receiving antenna design, for 400MHz and 430MHz (one or the other) and able to sit inside something the size of an I-pod.
Textbooks, papers, and other suggestions are all welcome here.
Re: Antenna Design Textbook - Small Format, Planar
Reply #1 - Jun 21st, 2009, 10:25pm
loose-electron wrote on Jun 20th, 2009, 12:56pm:
I think loop antenna(electric or magnetic current) is suitable for your application.
Electric current loop antenna and Magnetic current loop antenna(or Slit Antenna) were used in Pager System.
Especially magnetic current antenna is advantageous in the proximity of human body.
https://www.silabs.com/Marcom%20Documents/Resources/EZRadio_EZRadioPRO_Solutions...
This loop antenna is novel.
http://www.maxim-ic.com/appnotes.cfm/an_pk/4302
http://www.maxim-ic.com/appnotes.cfm/an_pk/3621
http://www.maxim-ic.com/appnotes.cfm/an_pk/3622
http://www.micrel.com/_PDF/micrf102.pdf ; Common electrical loop antenna
http://www.micrel.com/_PDF/micrf112.pdf
http://www.micrel.com/_PDF/micrf211.pdf ; Spiral antenna
The following book is very good and useful.
Warren L. Stutzman and Gary A. Thiele, Antenna Theory and Design, John Wiley & Sons, Inc., 1981.
« Last Edit: Jun 22nd, 2009, 9:08am by pancho_hideboo »
Reply #2 - Jun 22nd, 2009, 8:49am
This is a popular PIFA(Planar Inverted-F Antenna).
