Aug 16th, 2024, 7:47pm
gain expression for PAC analysis in ADE (Read 3463 times)
aNaloG_y
Jun 22nd, 2009, 8:04am
Hello All,
Does anyone know how to put output gain expression in  cadence ADE  for PAC analysis.?
At present I am will plotting it once the PAC analysis is over by selecting the PAC results,but I want to put expression before analysis similar to AC analysis
aNaLog_y
Re: gain expression for PAC analysis in ADE
Reply #1 - Jun 22nd, 2009, 8:27am
aNaloG_y wrote on Jun 22nd, 2009, 8:04am:
See http://www.designers-guide.org/Forum/YaBB.pl?num=1237656418/3#3
but I want to put expression before analysis similar to AC analysis.
What do you mean ?
aNaloG_y
Reply #2 - Jun 22nd, 2009, 8:40am
Hi pancho_hideboo,
In AC analyis if you write gain expression in ADE e.g 20*db20("VT(/<netname>"),this expression will be plotted at the end of AC analysis.
But in PAC,once run is over I need to go and select the PAC results and then plot the gain expression using calculator.
Ramesh
Reply #3 - Jun 22nd, 2009, 8:54am
aNaloG_y wrote on Jun 22nd, 2009, 8:40am:
Not correct. This has to be VF(). And "20*" is redundant.
No, you don't seem to be familiar with Cadence ADE.
Choose "ADE>Results>Direct Plot" for both ac and pac with "Add Outputs=On".
Or use result browser for both ac and pac. Then invoke calculator and do "get expression".
In anyway, you can get following expressions in output field.
db20( v("/<netname>" ?result "ac-ac") )
db20( v("/<netname>" ?result "pac-pac") )
