Aug 17th, 2024, 12:21pm
folded cascode... (Read 4178 times)
somisetty
folded cascode...
Jun 24th, 2009, 11:51pm
hi all,
can u tell me why the name folded cascode?
why miller compensation not required in folded cascode OTA?
raja.cedt
Re: folded cascode...
Reply #1 - Jun 25th, 2009, 1:14am
hi,
  because it is single stage..so how you use miller compensation...generally in two stage miller compensation is required but the same two stage gain you will get in single stage if you use folded.
Rajasekhar.
nobody
Reply #2 - Jun 25th, 2009, 2:32am
The input pair is folded so that the input range is improved. Sometimes, the miller effect will have effects on PM.
raja.cedt
Reply #3 - Jun 25th, 2009, 5:40am
you mean miller effect at the input tx gate..any how your drain is low impedance because of cascoding..no problem
rajasekhar.
nobody
Reply #4 - Jun 25th, 2009, 7:42pm
Basically, you assume the impedance frequency is 1/gm, which is right @ high frequency and the gain is gm,inp/gm,cascoded.
However, the impedance is not low @ low frequency and you can try to derive the gain @ low frequency and see what you have.
raja.cedt
Reply #5 - Jun 25th, 2009, 9:30pm
yaa..its correct now you catch the correct point..pole at the input device is non dominant ..so it will be come into action at high frequency..so whats the problem..
Rajasekhar.
nobody
Reply #6 - Jun 25th, 2009, 11:46pm
It is my fault saying about the miller effect on PM. The miller effect will show up in SC ckt and has the influence on the loop gain. Sorry about that. The non-dominant pole is basically determined by PMOS or NMOS input pair.
