Aug 15th, 2024, 6:40pm
Corners_setup file in Cadence ADE (Read 2153 times)
sch
Jun 25th, 2009, 12:09am
Dear ALL
What is the corners analysis setup file in ADE ?
it can be load from ADE->tool->corner-file.
What is the contents?
sch
kevinvinv
Re: Corners_setup file in Cadence ADE
Reply #1 - Jun 25th, 2009, 3:07pm
I dont know for sure but if you have APTIVIA or sometimes called VSdE --  I HIGHLY recommend this tool for running corner analysis.
__________________
Kevin
Reply #2 - Jul 10th, 2009, 6:21am
And if you want to use the corners tool in ADE, you could always try reading the documentation. A lot of effort goes into writing documentation, and it's  remarkable how little effort goes into reading it  :o
Before anyone replies, I know it's not perfect, and may be hard to find things, but for a big suite of tools it's hard to get the balance right between overview and detail.
