Jul 16th, 2024, 6:18pm
Running Spectre Stability Analysis at a non-Quiescent operating point. (Read 5762 times)
kevinvinv
Jun 25th, 2009, 3:06pm
I'd like to run a transient analysis on this circuit up to 100nS and THEN perform a stability analysis under that operating point.  Does anyone know if this can be done?  Kundert's book mentions it with AC analysis but I cant get this to work with STB since the STB run happens BEFORE transient...  at least that is the first problem.
Thanks.
__________________
Kevin
Re: Running Spectre Stability Analysis at a non-Quiescent operating point.
Reply #1 - Jun 26th, 2009, 5:27am
Use "prevoppoint=yes" or "readns" of STB analysis with Transient analysis.
« Last Edit: Jun 26th, 2009, 11:15pm by pancho_hideboo »
Dipankar
Reply #2 - Jul 8th, 2009, 6:37am
Dear Kevin,
                   Are you running simulation through ADE ? Then you can try like this .  :  analyses -> tran -> option -> actimes = 100 n
        acname = stb.
In your analysis section both tran and stb should be enabled properly. and then you run the simulation.
With Thanks and Regards,
Dipankar.
