Jul 20th, 2024, 12:25pm
Reference for I-/Q-channel ADC (Read 2860 times)
Berti
Jul 01st, 2009, 7:20am
I have two (I- and Q-channel) delta-sigma ADCs for cellular, each with his own reference voltage buffer. I am wondering whether it makes sense to share the buffer (thereby minimizing mismatch on the voltage reference which increases image rejection etc.) or is this a bad idea because of cross-talk between the two channels?
jbdavid
Re: Reference for I-/Q-channel ADC
Reply #1 - Jul 16th, 2009, 6:09pm
If I were a design lead, I wouldn't accept your decision based just on an answer from this forum.. I'd spend an hour with you just reviewing how you modeled the potential interaction, and looking over the simulation results on which you based your decision..
Its the kind of thing good designers write papers about..
jbd
jbdavid
Berti
Reply #2 - Jul 21st, 2009, 11:02pm
I agree, but it is always good to collect some other opinions ....
wave3x
Shang Hai, China.
Reply #3 - Aug 18th, 2009, 11:14pm
I think IQ ADC need not to use independent reference driver, just to simplify the design and layout. Cross-talk will not be a big issue.  image rejection also be a less significant issue just if you pain a little attention about it. Of course I assume your system does not need a IR < -50dB.
Berti wrote on Jul 1st, 2009, 7:20am:
