I think IQ ADC need not to use independent reference driver, just to simplify the design and layout. Cross-talk will not be a big issue. image rejection also be a less significant issue just if you pain a little attention about it. Of course I assume your system does not need a IR < -50dB.
Berti wrote on Jul 1st, 2009, 7:20am:Hi all,
I have two (I- and Q-channel) delta-sigma ADCs for cellular, each with his own reference voltage buffer. I am wondering whether it makes sense to share the buffer (thereby minimizing mismatch on the voltage reference which increases image rejection etc.) or is this a bad idea because of cross-talk between the two channels?
